59 Turn Signal switch Assembly - NCRS Discussion Boards
  • Steve Epps
    Looking at various parts books, I see a flat wedge spring return listed (with no real pictures showing WHERE it belongs), and upon disassembly of my steering/turn signal I see no flat spring, just the circular canceling assembly that activates the turn signal switch.
    Thanks again! for any words or images to help make this old guy have a clearer understanding of what is what.
    -Steve
  • Mike M.
    • May 31, 1974
    • 8385
    Re: 59 Turn Signal switch Assembly
    the c-1's, as well as the 53 and 54 chevy pass.cars(which shared similar if not identical turn signal apparatus,) had a flat spring steel band that served to return the dirc signal swithch handle to neutral. check out local junk yards for the 53-54 chevy pass cars for the spring steel piece you are mising. good luck,mike
    • Ed Jennings
      You should see a pair of slots on the left side of the bell where it fits.
      • Steve Epps
        Yep, If I had gotten out my eye glasses and taken a good look I would have seen those two slots and might have figured it out.
        Guess besides the flat spring, I need to buy a round cord to hang my eye glasses around my neck.
        Mike - Ed
        Thanks again !!!
        -Steve
