c3-71 -Delco 44TS SPLug Question - NCRS Discussion Boards
  • Peter M.
    • April 1, 2003
    • 137
    Have 71 Lt1. Went to take out spark plug and it was a Declo 44TS. Is this ok to use - should I get the same or a different set of Delcos?
    • 43221
    Re: c3-71 -Delco 44TS SPLug Question
    Peter----
    The GM spec plug for your application was AC R 43T. An R 44 TS is a slightly hotter plug with an extended tip. From a functional perspective, this is probably a BETTER all-around plug for your application than the original-spec plug. If I were you and you are satisfied with these plug's performance, I would stick with that plug (or, for my money, the Champion equivalent of that plug).
    • Peter M.
      • April 1, 2003
      • 137
      Re: Thanks Joe !!!! NM *NM*
