C2 Battey - NCRS Discussion Boards
C2 Battey
  • john lokay
    C2 Battey
    I have a three year old Exide battery in my 66' and I noticed that a mustard color residue has built-up on top of the battery by one of the cell cap areas. Is this an indication that the battery is being overcharged or is the battery just going bad? The car starts up fine from a cold start so the battery is still putting out sufficient power. Thanks
    • 15680
    Re: C2 Battey
    Is this a "maintenance type battery" - one that requires periodic water addition?
    If so and only one cell is showing deposit buildup, it could be that cell is overfull.
    If your ammeter is normally not more that a needle width or two above the zero line then it is probably not overcharging, but you should check system voltage and make sure it is in the range of 13.5-14.5 volts when the engine is running.
    • Jerry S.
      • May 31, 2003
      • 145
      Re: C2 Battey required
      Who is the vendor that attends all the shows and has great batteries? Nice modern reproductions?
      • Joe R.
        • July 31, 1976
        • 4551
        Jerry,
        That's "Restoration Battery" in Cincinati Ohio. The guys name is Tom Kobman and he can be reached at 1 513 451-1038. Don't forget to ask him for a Battery Tender for your new battery.
        Tell him J.Ray recommends "Restoration Battery" for all your battery needs.
        JR
