Twist'n the night away - NCRS Discussion Boards
  • Larry P.
    • June 30, 1999
    • 481
    Last night we shimmed the body bolds and adjusted the height and door fit.(60)
    Front left needed about 1/2 inch more than the others in the middle to get the front same height on both sides. The right rear needs about 1/2 inch for doors to fit perfect BUT then the right rear is higher than left.
    I assume the ribbed rubber spacers go where ever they will help and fit.
    They don't fit snug where they belong so?
    All in all it's pretty close but suggestions would be appreciated.
    Does the rubber shim go against the body or frame?
    Is 1/2 inch diff to much?
    Larry
