'64 COOLING SYSTEM FILL PROCEDURE - NCRS Discussion Boards
  • Fred Hammerle
    Any special procedure or tips to be followed in filling a completely dry cooling system after a radiator change out to a new DeWitts? THANKS!
    • 15674
    Re: '64 COOLING SYSTEM FILL PROCEDURE
    No. Fill the system slowly. When the level in the tank reaches about half, and it won't take anymore, start the engine. When the thermostat opens the level will drop. Fill back to about half level and when it won't take anymore, install the cap and take it for a short low speed drive. The system should self bleed once the thermostat opens.
    Let the system cool and check and correct the level as required.
    • Fred Hammerle
      Thanks Duke. Fred
      • Jim T.
        • March 1, 1993
        • 5351
        To get the old coolant out of the engine block remove both side block drains.
        • Fred Hammerle
          Thanks Jim ... already drained the block on both sides. Fred
            I've always filled a dry system through the thermostat opening in the intake until the coolant rises to the level of the opening, install the thermostat and housing (already attached to the upper hose), then top off through the expansion tank filler. Start it up, let it come up to temp so the thermostat opens and you see circulation in the tank, then check the tank for 1/2-full when it cools down. Never had an air pocket or had to "burp" one.
            • Dave F.
              • December 1, 2003
              • 508
              John,
              Your method is my understanding of the safest way to ensure that as much coolant as possible will get into the system. For me, with having to break in the cam on a fresh engine rebuild, my concern is to guard against overheating, especially during this process. Mine is a 68, with a closed system using the supply tank as the fill source. I have the oil pressure & temperature gage, radiator, core support, and metal shroud all in place, and plan to use my 30" shop fan directed at the radiator. Is there anthing else I can focus on?
              Dave
              • Roger Legge
                I know this thread is about the cooling system, but you mention a concern with overheating on an initial start/break-in. Make sure the ignition timing is not retarded because this can cause an engine to run hot.
                Roger
                • Dave F.
                  • December 1, 2003
                  • 508
                  Thanks Roger. I do have a new vacuum advance, plus I replaced the amplifier on my Transistorized ignition, and some good old fashioned "racing fuel" in the tank, so I'll advance the timing as far as she'll go
                  • Randy Adams
                    I've used John's method twice and never had a problem.
                    • Fred Hammerle
                      Thanks for all responses. Most appreciated. Fred
                        A typical plastic radiator fill funnel with holes drilled in it as shown below simplifies no-spill filling through the thermostat opening - it stands up in the hole by itself, and you can monitor the coolant level as it rises without having a sudden "overflow" around the edge.
                        • Dave F.
                          • December 1, 2003
                          • 508
                          Nice tip, John. One born from experience I'm sure! Thanks.
