67 turn signal wire assy - NCRS Discussion Boards
  • Roy B.
    • February 1, 1975
    • 7044
    Who or where can I get a turn signal wire assy ? My flasher nob broke off and the left turn arm won't stay down. 1967
  • Warren S.
    • April 30, 1987
    • 100
    Re: 67 turn signal wire assy
    Roy,
    I got a turn signal switch from my Chevrolet dealer a couple of years ago. The one I got was for a telescopic steering column and I think that it was a different part number than a non telescopic one. If I remember correctly, the switch is applicable to 67 and 68 Corvettes only.
    • Ed Jennings
      There was a Delco replacement available from the Chevy store a few years back, which required an adapter cable to work and a lot of "fitting". There is now a reproduction available and is carried by all the usual catalog vendors. Costs around $60 if I recall correctly.
      • Gerard F.
        • June 30, 2004
        • 3806
        Funny, my left turn signal arm won't
        stay down either, but the arm stays up for a right turn. Is there a cheap fix, other then changing the switch? 1967 also.
        Jerry Fuccillo
        #42179
        Jerry Fuccillo
        • Justin N.
          • February 1, 2004
          • 318
          Shee-Mar Rules!
          Roy,
          I found my 67 non-tele signal at Shee-Mar for $52 I think. (303)678-5334 It has the original Delco Remy connector also.
          Justin #43162
          • Paul L.
            • November 1, 2002
            • 1414
            Re: Funny, my left turn signal arm won't
            Gerard,
            Same problem. The little leg on the cancelling cam broke off (see pic). I could not devise a cheap fix so ordered a unit from Shee-Mar.
            • Paul L.
              • November 1, 2002
              • 1414
              BTW on Ordering from Shee-Mar
              Do not order from the web site. The listing (SM211) for 1967-68 is not correct. That will fetch you a 1969- unit. Telephone and ask for Scott Farrell. I have brought that incorrect listing to his attention and he knows the right part number.
              • Roy B.
                • February 1, 1975
                • 7044
                This one is on E-bay and his feed back selling parts is great . He said you only remove the little dash light for it and it works great. Cost $95.00 e-bay #2489876628
