Crankshaft pulley - NCRS Discussion Boards
Crankshaft pulley
  • Dennis Corrigan
    Crankshaft pulley
    Trying to determine the correct pulley or pulleys for the crankshaft on a '66 base engine. Am adding P/S. Car has no A/C. Existing crank pulley is a single groove GM part # 3755820 which is correct per the assembly manual w/o P/S. It appears that there should be some combination of pulleys to provide three grooves. Track one for the alternator and track three for the P/S. Various catalogues are confusing at best. Any help is appreciated.
  • Mike M.
    • May 31, 1974
    • 8388
    Re: Crankshaft pulley
    check with long island corvettes. they ad in driveline. mike
    • Eugene B.
      • May 31, 1988
      • 710
      Dennis,
      Hope that I'm not providing misinformation to you. I can tell you what pulleys are used on the '65 base motor with power steering.
      The pulley combination that attaches to the harmonic balancer has a total of three grooves. The inner pulley is P/N 3744043 and is 6 3/4 inches in diameter. Bolted to that pulley, is pulley P/N 3751232. This makes the three groove pulley a total of 2 inches wide.
      Hope this information helps.
      Gene
