1971 LT-1 Tachometer - NCRS Discussion Boards
  • Mark Chance
    Can anyone tell me where the redline should be on a 1971 LT-1 Tachometer? I'm considering purchasing a car online and the picture of the tach has the redline at 6300. Does this seem correct for the car?
    Mark
  • Robert E.
    • April 1, 2004
    • 398
    Re: 1971 LT-1 Tachometer
    The redline is 6500.
    • Mark Chance
      Bob,
      The yellow band starts at 6300 and goes to 7000. I can't quite see a red line. Does this sound correct for a 71 LT-1?
      Mark
        • 15678
        Tachometers for mechanical lifter engines going back to at least '63 carry the following color coding.
        Yellow zone: 6300-6500
        Red zone: 6500-7000
        Fading can make the color change at 6500 hard to discern,
        I'll leave it to owners of '71-'72 "low compression" LT-1s to confirm, but I thought I heard that the 9:1 compression LT-1s may have carried a lower redline tach than the 11:1 CR version of 1970.
        • Paul O.
          • August 31, 1990
          • 1716
          Duke's yellow/red zones correct for 71 LT-1. Paul
          • Mark Chance
            Duke / Paul,
            Thank you very much. I looked closer at the picture and saw the yellow/red split at 6500 as you indicated. I sincerely appreciate the help.
            Mark
            • Charlie P.
              • July 31, 2003
              • 260
              This talk about tachs made me wonder- if the yellow line starts at 6300, and means you should watch out because you're about to hit the red line, and if go to the red line at 6500, haven't you now reached the point where you could blow the engine up? So what if you continue on to 6750? You could REALLY blow it up? And on to 7000- you could REALLY REALLY blow it up? Shouldn't it be a red point? Just wondering.........
                • 11644
                Like your 71 ever gets above 3000 rpm???
                PH
                • Charlie P.
                  • July 31, 2003
                  • 260
                  ONLY gonna happen if I go for PV
                  • Dave S.
                    • August 31, 1992
                    • 2925
                    "IF" you go for a PV ?You mean when,right? *NM*
                    • Charlie P.
                      • July 31, 2003
                      • 260
                      Oh, Yeah, Dave, a Freudian slip
                      Radio is in and working. Speakers were bad, so the whole dash had to come out. 90% back together, so I will find out what I left un-hooked when I start it up.
