69 wiper motor - NCRS Discussion Boards
69 wiper motor
  • Frank & Paula Lowery
    69 wiper motor
    We recently had our wiper motor restored and need to know where the different hoses connect. We have the AIM, but the detail is not clear. It has the three nipples on the passenger side that point down. And the three on the drivers side. Two pointing down and one coming from the side. We are wondering where the red stripe headlight washer hose connects, along with the washer bag hose and remaining connections. If IVAN doesn't get us we'll try to hook it up this weekend. Thanks in advance for your help. Frank & Paula Lowery. #28485.
  • Jeffrey S.
    • May 31, 1988
    • 1882
    Re: 69 wiper motor
    Frank and Paula:
    Here's how you hook it up: the middle port on the passenger side is the inlet from the washer reservoir. The other 2 ports are outlets from the pump and are joined together by a "T". This line runs to the outboard of the 2 ports facing down on the driver's side. The horizontal port on this side goes to another "T" that brancehes off and feeds the wiper arms. The other port facing down (inboard) on the driver's side feeds the headlamp washer. Are you confused yet? Hope this helps.
    Jeff
