C1 Transmission Removal - NCRS Discussion Boards
  • Dennis A.
    • April 30, 1999
    • 1010
    Going to remove my 4-speed transmission...Any advise on how to remove the shifter/linkage or get it out of the way
    so the transmission can slide back on guide pins would save me a whole lot of time. Car is a "61
    T.U.
  • Mike M.
    • May 31, 1974
    • 8396
    Re: C1 Transmission Removal
    i have a 1/4" drive snap-on socket, extension and flex socket set that allows for easier removal of the shifter. good luck, mike
      Remove the transmission mount crossmember first for much improved access to the shifter (and note any shims/washers that come out with it).
      • Dennis C.
        NCRS Past Judging Chairman
        • January 1, 1984
        • 2409
        The shift linkage will have to go. Remove driveshaft early on for easier access to the rear trans mount bolt. Lose the cross mount asy & speedo cable. Even at that, it doesn't exactly fall out. Dennis
        • Dennis C.
          • January 1, 1984
          • 2409
          Should have said...
          ... remove driveshaft early on for easier access to the rear shift linkage mouting bolt - sneak up on it from behind. Dennis
          • Christopher R.
            • March 31, 1975
            • 1599
            Remove the driveshaft. Support the engine, and remove the transmission mount. Remove the speedometer cable. Lower the transmission, but not so much that the fan hits the shroud, or the distributor shielding hits the firewall. You can then get at it. Lowering the engine/transmission lowers that end of the transmission some out of its tunnel. Little fingers help.
            Support the engine with a "saddle" made to bridge the oil pan and support the weight from the block/oil pan rails. I then use a scissors jack to lower and raise it after I remove the mount/crossmember. You could jack on the oil pan, but you risk denting it. Those things are expensive. Look up "saddle" for messages by John Hinckley in the archives for directions and pictures on how to build this. To summarize, the saddle is made from 1" x 6" pieces of lumber forming a "U". Get the picture. It tells a 1000 words.
              Here's the "saddle" - 2x6 base, 1x6 sides that snug up to the sides of the pan, 1" higher than the depth of the pan. The ultimate low-cost tool
              • Dennis A.
                • April 30, 1999
                • 1010
                Re: T.U.
                Thanks to all...I have the guide pins & saddle ready to go, There shall be happy times this weekend under a Vette that I should have rebuild the transmission when I had the body off...Pay the price and have more fun.
