C1 rear end fluid capacity - NCRS Discussion Boards
  • Steve Epps
    Question is how much ?
    As always ...
  • Dave F.
    • December 1, 2003
    • 508
    Re: C1 rear end fluid capacity
    Typical for most applications is you fill until lubricant starts to come out the drain hole.
    • Terry D.
      • May 31, 1987
      • 2691
      Dave is correct, but for buying purposes you will need 4 pints. If it is a posi also get the additive from GM.
      • Dave F.
        • December 1, 2003
        • 508
        Sorry....I should have added the capacity required. Also, be sure to take a big whiff of the posi additive before you put that in. PePe Le Pew
        • Dave F.
          • December 1, 2003
          • 508
          Then go out and do some Figure 8's ASAP *NM*
