1961 Starter - NCRS Discussion Boards
1961 Starter
  • Ray C.
    • June 30, 2001
    • 1132
    1961 Starter
    While starting the 61 this morning the starter would not disengage in the run position. After a couple tries it started correctly. I drove the car for a couple hundred feet and the starter engaged while the car was moving. Where is the first place to check, switch or solenoid?
    Thanks f or the help!
    Ray #36314
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
  • Mike M.
    • May 31, 1974
    • 8385
    Re: 1961 Starter
    switch would be first place i'd inspect. good luck, mike
    • Ray C.
      • June 30, 2001
      • 1132
      Re: 1961 Starter
      Thanks Mike & Donald!
      I removed the switch and checked it with an electrical meter in the beep OHM position. I attached one lead to the SOL terminal and the other to the battery terminal. When I turned the key to the on position the meter beeped. The meter also beeped in the start position. I took the switch apart and the internal parts seemed to be in good condition. I did notice where one of the contacts seemed to have arced and there was some black soot. I cleaned the switch parts with electrical contact cleaner and 1500 grit paper, replaced grease only where grease was prior to disassembly and reassembled the switch. I checked the switch with the OHMmeter and only had a beep on SOL when the switch was in the start position not in the on position. I will reinstall and see if my problem is fixed. Any ideas of what would have caused this to happened?
      Thanks! Ray # 36314
      Ray Carney
      • Mike M.
        • May 31, 1974
        • 8385
        Re: 1961 Starter
        contacts arc every time they make contact(when ign switch is in start position). not at all uncommon problem with older delco ing switches. mike
        • Ray C.
          • June 30, 2001
          • 1132
          Re: 1961 Starter
          Thanks for all the help!
          Switch is fixed and working just fine!
          Ray
          Ray Carney
