Holley Carb - NCRS Discussion Boards
Holley Carb
  • steve beech
    Holley Carb
    I have a Holley carb with the numbers
    3989021
    List 4801-1
    1795
    With this date code and
    GM part number, what was it off of?
    Thanks for the help.
    Re: Holley Carb
    Steve -
    It's a late June '75-built service replacement for a '71 LT-1.
    • Peter M.
      • April 1, 2003
      • 137
      Re: Holley Carb
      John,
      So I can learn - explain how you arrived at that please. I also have a 71 LT1.
      Also, how do you tell if you have a service replacement 4801 vs original one?
      Peter
      • steve beech
        Re: Holley Carb
        Thanks for the info---Steve
        • Warren F.
          • December 1, 1987
          • 1516
          Re: Holley Carb
          Peter:
          The top number is the GM list #. The second number is the carburetor model #. Originals do not use the -1, this would indicate a change in the carburetor since originally issued as OEM usage. A good example would be a different metering block number used since originally issued. The third number is a julian date system used for manufacturing date. That is the 175th day of 1975, approximately June 15th or 16th most likely.
            • 15601
            Re: Holley Carb
            As a point of clarification. Some models of Holley carburetors did get a -1, or -1A, following the list number during their OEM run. The 1972 LT1 is one example.
            • Peter M.
              • April 1, 2003
              • 137
              Re: Holley Carb
              Terry,
              I am at work now(I have 71 Lt1) but I think I have a 4801-1 carb with a build date of early August 70. Since they started making 71's in August 70, would Holley have already had a change that quickly? Since my car was built last week of August, how early would the 4801 without the -1 have been made that would have shown up on the car when it was put on the assembly line?
              Peter
              • Peter M.
                • April 1, 2003
                • 137
                Re: Holley Carb thanks for info NM *NM*
                • Warren F.
                  • December 1, 1987
                  • 1516
                  Re: Holley Carb
                  Peter:
                  I have a '71 LS-6 coupe, April 20th build date. Original known carburetors on these cars have 4803. LS-6 cars were built thru July '71. I have a NOS LS-6 carburetor that has 4803-1 with a 132 date code, indicating 2nd week March 1971. The primary metering block number is a different number than on the 4803 carburetor. I haven't been able to verify if this later carburetor number is also in usage on original known cars.
