Carter Carbs - NCRS Discussion Boards
Carter Carbs
  • Steve L.
    • May 31, 2001
    • 34
    Carter Carbs
    I have a Carter WCFB with the following numbers air horn # 1354 main body # 0-207 There is a number AB433S on the plastic choke adjustment. My question is what year car is this carb correct for?
  • James F.
    • December 1, 1985
    • 596
    Re: Carter Carbs
    Steve,
    Air horn #1354 was used on 1958 single 4BBl. However main body for this air horn would be 0-208 or 0-1208. Throttle body # 1-1386. Regards,
