brake and clutch master cylinders - NCRS Discussion Boards
  • Mike M.
    • May 31, 1974
    • 8388
    need I.D. of the master cyls for the brake and clutch systems used on the c-4 vettes, specifically a 96 front and rear suspension c-4. what's available (non-stock) is 3/4, 7/8 and 1" id master cyls. assume the brakes would prefer the 1' bore mast cyl but what about the clutch slave cyl? the willys thanks you(it is vette powered) mikie
  • Dick W.
    • 10483
    Re: brake and clutch master cylinders
    Do it run yet, or are ya just a sitting in the seat going rumba, rumba?
    Dick Whittington
      • 43221
      Mike-----
      The brake master cylinder bore for C4s is 0.875". I don't have a spec for the clutch master cylinder bore.
