1967 L-79 AC Comp. dating - NCRS Discussion Boards
  • Allan Wicklund
    Hello to all, I put factory A/C from a wrecked car, in my "67" many years ago. Currently working on making it correct to 67. 66 and earlier had an STV and 67 a POA. Newly discovered info. Therefore, I am replacing my STV valve with a POA etc. I'd like to put the correct date coded Compressor in the car. Anyone able to email me a picture or provide additional details? Happy Motoring to all! Al W.
  • Allan Wicklund
    Re: 1967 L-79 AC Comp. dating
    How about a Ser.# of 6555302? Is there a casting date, such as D 14 Y? Help,Please!
    • Peter L.
      • May 31, 1983
      • 1930
      Al - Your post makes it sound like the system you installed is from a '66 or earlier midyear, so several of the components or the component configurations will be different from the corresponding components of the '67 C60 system. What picture(s) are you interested in? Pictures of, the Frigidaire label, compressor configuration, pulley, muffler, etc? Also, you'll want to find a rear compressor plate which has a manufacture date code appropriate to the compressor build date to make the compressor assembly "correct" and correctly dated. I'm sure someone can help with the pictures if you can specify your needs. Pete
      • Allan Wicklund
        Thanks pete! I'm currently gathering info. and parts to convert system. I have the correct POA and Expansion valve and will seek whatever else I need. Took lots of pictures at Carlisle last week and should be able to identify more from them. I am trying to figure out if Compressor Casting 6555302 is correct and what a D 14 Y casting mark identifier could mean. My car has a 6-6-67 build date. I've had it since 1973 and raised four kids with it! (Same wife too!). Thanks for your interest. Al W. P.S. Who can supply a Frigidar label properly stamped? Hmmmm!
        • Randy S.
          • January 1, 2003
          • 586
          Allan,
          I am not aware of any supplier furnished stamped compressor foil label. However I stamped my own with an 1/8" punch set. I made a fixture to keep the alignment level. Others have recommended typewriter.
          Randy
          • Allan Wicklund
            It's a thought Randy. I'd really like to duplicate the OEM label so I'll keep lookin around. What year car is yours? Original Comp? I'm going to share all my research once it's completed if your interested. Thanks, Al W.
            • Randy S.
              • January 1, 2003
              • 586
              Allan,
              My car is a 66 300hp. As I recently rebuilt the system last year I thought I'd offer my suggestions on the compressor label
              66 foil label is unique. The stamping is, I believe is 2 digit month, 2 digit day, 1 digit shift,1 digit year but I would have to look that up for you to be sure. My compressor is an A-6 original type but I am not certain it is original. If you decifer the casting code on the compressor end advise. One problem you will probably have is no one makes dated/marked freon hoses.
              Good luck
              Randy
              • Allan Wicklund
                Hello Randy, Thanks for the response. I have a picture of what I believe to be the correct A-6 end plate. I can email it as an attachment if your interested. The foil label is going to be a challenge and thanks for your input. I'm not going for Top Flight so the hoses are not an issue. If I could get them I'd like it. I'll look for your response! Thanks!
                • Allan Wicklund
                  Hi Pete, Thanks for your Post! I'm looking for pictures of the end plate on 1967 cars. Also the Labels on the A-6 Comp. I have the correct parts to do the STV to POA conversion so I'm getting close. Thanks again, Al W.
                  • Peter L.
                    • May 31, 1983
                    • 1930
                    Allan - Have pictures for you. Contact me. Off line E-mails have failed. Pete
