Early C3 wiper arms - NCRS Discussion Boards
Early C3 wiper arms
  • Michael W.
    • April 1, 1997
    • 4290
    Early C3 wiper arms
    Are 68-73 wiper arms similar in configuration? I'm looking for a correct replacement set for my '73
    Mike
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: Early C3 wiper arms
    Mike They are all the same. Lyle
    Lyle
      • 43221
      Lyle and Mike-----
      1968 is not the same as later. 1968 was a one-year-only design as far as the wiper arms are concerned. As far as I know, they cannot be used on later models. Also, as far as I know, the 69-74 were the same, although I suppose it's possible that late 74 used the 75+ design. The 75-82 pieces became the SERVICE pieces for 69-74 and will retrofit to 69-74. They will not retrofit to 68, though.
      • Harmon C.
        • August 31, 1994
        • 3228
        Joe did the 68 have the metal washer tubes as I have about 50 examples and see no difference but all I ever bought was the metal tube type. The change over in 74 happened very eary and most 74's will have the rubber hoses for the washers.The TI&JG puts the change about vin 5000 or 5th-12th of Oct. 73. Lyle
        Lyle
          No....
          '68 was unique in that it had no squirter tubes running alongside the wiper arms.
            • 43221
            Re: No....
            Jack and Lyle-----
            Yes, 1968 did not have the tubes. However, I think that there was some other functional difference between the 68 and later arms also. I've forgotten what it is, though.
            • Geoff C.
              • May 31, 1979
              • 1613
              68 is all by itself - no brass piping *NM*
              • Stephen W.
                • March 1, 2002
                • 301
                Re: No....
                Now you guys have me curious. I'm gunna have to dig out the box I have the original 68 wiper arms in to see what they look like. Now my 68 is a late production ( July 68) if that makes any difference.
                • bruce11495
                  Joe....Do you have a part number for the right side wiper arm for 69-74? I know my 74 had the "new" style, otherwise I would have exchanged them when I sold it.
                    • 43221
                    bruce-----
                    The original PRODUCTION and SERVICE wiper arms for 69 were:
                    left side----GM #3956245
                    right side---GM #3956246
                    In late 1969 the right side arm was discontinued and replaced by GM #3965154. The 3956245 and 3965154 then continued to be used right through E1974.
