How to get wax out of textured door jams, etc? - NCRS Discussion Boards
  • John Chesher
    When you open the doors on my '81, there are a few areas in the door jam that are painted but have a rough surface. The previous owner must have waxed these areas, as there is a bunch of wax build up in the crevices of the texture. The white wax looks pretty bad on a black car. What is the easiest way to get the wax out of these crevices? Thanks!
  • Stephen L.
    • May 31, 1984
    • 3158
    Re: How to get wax out of textured door jams, etc?
    Try some soap and water along with a soft brush (like a tooth brush) and some patience.......
    • Grant M.
      • August 31, 1995
      • 448
      I think a gentle degreaser like 'Simple Green', which effectively removes wax from soft trim etc, used with a the a/m toothbrush, would work.
      grant
      • Brian M.
        • February 1, 1997
        • 1840
        I'd use 3M Wax & Grease Remover with a tooth brush.
        • Tracy C.
          • July 31, 2003
          • 2739
          Prep-Sol from your automotive paint supply house
          will work. Or you might try common Mineral Spirts followed by hot soapy water to remove any remaining oily residue.
          good luck,
          tc
