Joe L - AC GF 482 Fuel Filter - NCRS Discussion Boards
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    During your extended leave, I tried to find info on this particular filter to no avail. Can you enlighten me on its use and current availability. In this particular case, its use is simply as an "incorrect" in-line filter of gasoline on an "older" vehicle. TIA, Dennis
    • 43232
    Re: Joe L - AC GF 482 Fuel Filter
    Dennis-----
    The AC GF 482 fuel filter is a metal cannister style filter with 3/8" hose nipples on either end. As far as original application goes, it was a VERY limited-use piece. It was used only on 1982 and 1984 Corvettes with Cross-Fire injection. It was used on 1983 Corvettes, too, but none were ever sold to the public. It's configuration would also lend itself to use for other applications as an "add-on", in-line filter.
    The GF-482 is still available from Delco dealers under that number and it's available through GM dealers under GM #25055066. It's about 11 bucks list from GM dealers and about 7 bucks from Delco dealers.
    • Dennis C.
      • January 1, 1984
      • 2409
      Once again, my thanks for your help... DC *NM*
