64 Spin On Oil Filter - NCRS Discussion Boards
  • Don Hege
    Will a GM 68-82 spin on oil filter adapter work on a 64 block? One vendor mentions using the 68-82 adapter on the earlier blocks but I heard it would not work. Which is correct?
  • Craig S.
    • June 30, 1997
    • 2471
    Re: 64 Spin On Oil Filter
    Since it bolts where the original mount for the cannister filter was, and these were common for many years, I don't see why it wouldn't work......Craig
      • 43232
      Don-----
      The 68+ oil filter adapter will not work on a pre-68 block. A special adapter is required. These are available in the aftermarket.
      • Craig S.
        • June 30, 1997
        • 2471
        Re: 64 Spin On Oil Filter- correction
        When I saw Joes post, I realized I was refering to the aftermarket not GM adapter, sorry for any confusion I created.......Craig
