C1 - 1960 Service Instructions (Stamps on block) - NCRS Discussion Boards
  • Tom D.
    • September 30, 1981
    • 2134
    What were the instructions to the dealer in 1960, when a service replacement block was installed? Or, did such blocks arrive from Flint with stamped numbers on them?
    I have a ...519 block with "S 6 9 60" (or possibly "S 6 9 0") on the pad. The alignment of the letters indicates individual "hits" from a set of numbering tools.
    Tom D.
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
  • Loren L.
    • April 30, 1976
    • 4104
    Re: C1 - 1960 Service Instructions (Stamps on bloc
    After the strike was over, St Louis started stamping VIN derivatives (Nov); dealers were also instructed to do so on replacement warranty blocks. However, I would have NO IDEA as to how to begin to decode your stamping - what is the casting date of the block?
    • David D.
      • 330
      Tom, I worked as a light mechanic at a Chevy dealer in the 60's. I vaguely remember that one of the heavy mechanic's used to stamp a service replacement block or short block (don't remember which) with an "S" for service engine and the date installed. In your case of "6 9 0" or "6 9 60", it would indicate the replacement block or short block, was installed June 9th, 1960. So, if your car was built before that date, I would tend to believe that is the case. I really don't remember if there was a factory directive, that this was to be done when a block or short block was replaced under warranty or not. Maybe someone else can add some more info to this. Hope this helps, FWIW. Dave
      • Tom D.
        • 2134
        Thanks - It's Cast - E 8 0
        Should have mentioned this before. I was told the engine was a dealer replacement for a March 18th FI block (which didn't last very long). The replacement engine story came with the car, and seems to fit.
        Michigan Chapter
        Tom Dingman
        • Tom D.
          • 2134
          Thanks Dave and Loren
          Good feedback! I was told the engine was a dealer replacement for a March 18th block. Guess it would have been a warranty job, probably at the selling dealer in Wayne, MI.
          Someone later swapped the heads. Thanks again. Tom D.
          Michigan Chapter
          Tom Dingman
