Differential Gear Ratios for my '66 - NCRS Discussion Boards
  • Mark J.
    • March 1, 1996
    • 254
    I have two differentials to choose from and I want to confirm what I have.
    The first is stamped 11-37, GM #3735390. I believe this is a 3.36.
    My question is in regard to the second gear, which is stamped 12-37, GM #3756448. If this is a 3.08 I'll be a happy guy.
    My gratitude in advance,
    Mark R. Johnson
  • Mark J.
    • March 1, 1996
    • 254
    There I go answering my own questions...
    Colvin's, p.303, confirms what I have. Never mind...
      • 15679
      Re: There I go answering my own questions...
      Just to be sure you should count the turns ratio. It's always possible that the OE gearset was replaced with a different ratio.
      • frank mccracken
        If you go to all the work of replacing the....
        diff and the ratio isn't what the case #'s indicate, say 4.11's or something instead, that would be bad............ it's sure worth lookin' inside.
