What is that hose for? - NCRS Discussion Boards
+ More Options
Posts
  • William Dillon
    Looking at pictures of a correct '65 327/365 engine, I noticed what looked to me like a vacuum hose on the passenger side of the engine running from the base of the air cleaner to some where below the exhaust manifold? I'm not confusing this with the choke hot air tube which is correctly hooked up. Can anybody fill me in on this or have pictures they could send? Thanks.
    Bill
  • Joe C.
    • August 31, 1999
    • 4598
    Re: What is that hose for?
    It is the clean air hose. It sends filtered air into the bottom of the exhaust manifold heat tube, where it exits out the top, and into the choke housing.
    Joe
    • William Dillon
      Is there a hole on the exhaust manifold for some type of fitting? Does anybody still sell the correct parts? Thanks.
      Bill
      • Joe C.
        • August 31, 1999
        • 4598
        William:
        If you have the proper 3797902 right side exhaust manifold installed, then it has a sleeve inside, from top to bottom for the choke heat. Sometimes this tube corrodes and perforates over time, but replacements are available.
        Go to www.lics.com and look at section 22 of the catalog
        The parts for the entire assembly are: 45c, 51b, and 45g.
        Joe
        • William Dillon
          Thanks Joe!
          • Joe C.
            • August 31, 1999
            • 4598
            William:
            I'm sorry, but I gave you the wrong link, it should be:
            www.licorvette.com
            Does your manifold have the hole with the tube inside? This was not used after 1965, as the choke stove was moved to the intake manifold.
            Joe
            • William Dillon
              Yes, it has a hole on the top where I ran the steel tube up to the choke but I don't recall another hole for the fresh air tube - maybe it was too rusty to see.
              Bill
