66 hood repair help - NCRS Discussion Boards
66 hood repair help
  • Gary Wilkerson
    66 hood repair help
    The back section (under the hood)is separating in the middle from the top section. This allows the hood to flex where it would normally be rigid.
    It looks like the two are bonnded in small sections about 3-4 inchs long.
    What's the correct procedure to fix this?
    As always thanks for the help and comments!
    Gary
    Re: 66 hood repair help
    Repair the broken bond....
    • Wayne W.
      • April 30, 1982
      • 3605
      I think that you might be mistaking the non bonded inner edge with the bonded outer edge. The inner edge, done in the separated strips is not bonded. A non hardning cushion agent is used there.
      • Ronnie Robertson # 36786
        Repair/Replace
        Wayne,
        What is the correct repair/replacement for these inner cushions?
        • Gary Wilkerson
          Wayne,
          You're right, I think I mistook the cushion agent for a bond that had failed.
          The hood is not separated on the outer edges only in the area in the middle.
          The hood in question is on a 66 BB. My 64 SB hood is far more rigid.
          What is the correct material to use to cushion the center section?
          Gary
          • Wayne W.
            • April 30, 1982
            • 3605
            The factory used an orange colored substance, some call dum-dum. There are probably lots of non hardning puddies that would work OK. I use strip caulk most of the time.
              I don't recall the precise trade names of the product, but most body/paint supply store folks will know what you want if you ask for "hood gumdrops" material.
