1956 Casting Numbers (Matching Numbers) - NCRS Discussion Boards
  • Ken K.
    • May 31, 1999
    • 235
    I'm looking at a "numbers matching" '56. Can anyone tell me more about the casting numbers on the block, intake, exhaust maifolds, and other numbers?
    What other numbers/areas should I like it real good? Thanks
  • Robert Binder
    Re: 1956 Casting Numbers (Matching Numbers)
    The block should have a casting number of 3720991, and the Heads should have 3725306. You need to get all of the information off of the castings before you can determine if it is a correct car. You could have the correct casting number, and still have the wrong date.
    Robert
      There are a LOT of numbers to check and it'd behoove you to buy a copy of the '56-57 NCRS Judging Guide (STORE pull-down, this website)....
