C1 - Front End Rubber Seals - NCRS Discussion Boards
  • Brad K.
    • August 31, 1990
    • 414
    What was the shape of the rubber seals on the steering knuckle pivots and the swing arm pivots on the C1 front ends? Where they in fact o-rings about 1" diameter or were they circular rubber bands about 3/8-1/4" wide (rectangular in cross section)? Most OEM shafts I've run across contain the o-rings. But I think that my '59 front end end came equipped with bands (not sure if they were original)
    Brad
  • Dennis A.
    • April 30, 1999
    • 1010
    Re: C1 - Front End Rubber Seals
    Brad...
    My 61' had the rectangular seals. I replaced them (some were missing) with new rect. seals from CC. What mistake... some have already tore, If you do not plan to be judged, go with "O" Rings or a molded seal that is not a cut rubber band.
