I was installing my original oil pressure fitting into the rebuilt block and it fell into the hole. I had to fish it out with a wire. I swear I took this same fitting out of that hole a year ago. It is located forward/left of the breather tube.
Found that the hole is a 3/8-24. Does this make any sense? Is there any reason the rebuilder would have tapped in a larger hole?
What is my solution? Are there larger fittings available or some kind of adapter?
Thanks, Chris
Thanks, Chris
