Door hinge spring instalation - NCRS Discussion Boards
  • Harmon C.
    • August 31, 1994
    • 3228
    I need to install the door springs on the 75 Vette upper hinge and don't want to pull the hinges at this point unlees I need to. I have the tool that looks like a 1" socket made to do this. Can it be done on the car as I have no idea where the directions for the tool are. Lyle
    Lyle
    Re: Door hinge spring instalation
    Door hinge spring replacement is typically fast/easy with the special tool offered that appears to be a slot screw driver with slightly bent shaft and YES the R&R can be done with the door in place.
