C-3 LT-1 Lifters - NCRS Discussion Boards
C-3 LT-1 Lifters
  • steve beech
    C-3 LT-1 Lifters
    This may seem like a dumb question, but looking from the top of the engine valley, what is the visual difference between solid lifters and hydraulic?
  • Craig S.
    • June 30, 1997
    • 2471
    Re: C-3 LT-1 Lifters
    None that I am aware of. However, if you have your maifold off, you can remove the rockers and lifters (or at least one) to drain the oil to verify. Also, the lifters rattle if there is no oil and they are mechanical....Craig
    • steve beech
      Manifold is off. Lifters each have 6 small holes around the dished in center where the push rods seat.
      • Wayne P.
        • August 31, 1975
        • 1025
        A square spring holding the insides together would be hydraulic. No spring would be solid.
        • Clem Z.
          • January 1, 2006
          • 9427
          piddle valve solid lifters
          also use a spring to hold in the top. see if you can compress the lifter push rod cup and if you can it is a hyd lifter
          • steve beech
            Re: piddle valve solid lifters
            Clem--I pulled a lifter, and with all my strength cannot push the cup down using a pushrod. Solid??
            BTW the pushrod has the number 48829 on it. Whats that mean?
            Steve
            • steve beech
              Looking at all of the lifters as installed, the ones at the high spot on the cam are depressed a bit internally. Does that mean hydraulic for sure??
              • Clem Z.
                • January 1, 2006
                • 9427
                if the pushrod cup is below the snap ring it is a hyd lifter and it takes a lot of pressure to move the cup when the lifter has oil in it.
                • Clem Z.
                  • January 1, 2006
                  • 9427
                  48829 most likely a aftermarket part #
                  but off hand i am not sure what company.
                    • 15690
                    It's easy to confuse a piddle valve mechancical lifter with a hydraulic lifter because both are two-piece designs that are secured with a visible snap ring. The edge orifice mechanical lifter is a one piece design with no snap ring, so it is easy to differentiate.
                    The LT-1 cam was orignally equipped with the edge orifice type, so if you have a LT-1 engine with smap ring equipped lifters, I would be suspicious as to what cam it actually has.
                    I suggest you disassemble at least one lifter to verify its type.
                    The piddle valve lifters have an inertia valve ("piddle valve") that controls overhead oiling, and they deliver about 20 percent more oil to the rocker boxes than the edge orifice type. The piddle valve type was used with BB mechanical lifter cams, but all SB mechanical lifter cams engines were originally built with the one piece edge orifice type that controls overhead oiling on the basis of lifter to bore clearance.
                    The BB needs the additional overhead oiling because its valvetrain is more highly stressed, but the edge orifice type are best on SBs, especially if you don't have the larger capacity oil pan that was used on mechanical lifter SBs.
                    • steve beech
                      Thanks Duke
                      • Jeph South
                        I can send you a picture of an LT1 piddle valve solid lifter if you would like.
                        Jeph
                        • steve beech
                          Jeph, I'd love to have a pic of the lifter. If you can, an E pic would be good. Beech5@comcast.net
                            • 43232
                            Jeph-----
                            LT-1s did not originally use a piddle valve type lifter. They used an edge orifice type mechanical lifter. The only Chevrolet small block that ever used a piddle valve type mechanical lifter was the 67-69 Z-28 302 cid engine. All big blocks with mechanical lifters used the piddle valve type, though.
                            • Jeph South
                              Joe, you are always right on this stuff, so I bow to your knowledge.
                              This means that the lifter I have is not GM P/N 5231585?
                              I remember being in Steve's shoes when I opened up the valve train and found what I thought were hydraulic lifters. I must have stoppped asking questions when I found out they were solids. Are there any complications from running a piddle valve solid with the rest of my LT1 valve train? Thanks as always.
