5468309 Master Cylinder ID? - NCRS Discussion Boards
    I have a casting #5468309 master cylinder, with bleeders, stamped "HA" or "EA", that I removed from my '67 some time ago; I know this casting number when stamped "US" was used on '69 power disc brake Camaros. Anyone know what the usage of mine was?
    Re: 5468309 Master Cylinder ID? - Addendum
    Should have mentioned that it also has a deep-hole rear piston.
      • 43232
      John-----
      I'll try to remember to check on this when I get home. The '309' master cylinder was actually used on some Corvettes alternately with the '346' master cylinder. Both are 1-1/8" bore master cylinders. However, at the moment, I don't know what the codes you mentioned applied to. They were NOT used for Corvette, though. That much I know.
        Thanks, Joe - would appreciate any application info you may have when the local supply of lobster and clams is exhausted and you return home to "information central" I just want to be able to describe its application(s) accurately when I offer it for sale; nice core, but I have no use for it.
          • 43232
          John-----
          It appears that the original post has expired from the board. Could you please advise again regarding the code on the one that you have?
            Joe -
            It's casting #5468309, and the stamped code on the semi-circular area at the front is either "HA" or "BA" after cleaning it up some more, and it has a deep-hole rear piston. I know this casting when stamped "US" was used on '69 Camaros with power disc brakes, but I don't know the application of this one.
              • 43232
              John-----
              You're correct; the "US" coded master cylinder was used for 1969 Camaros with disc brakes. It was also used for 1969 Chevy II with disc brakes. The master cylinder assembly was originally known as GM #5463751.
              The "BA" coded master cylinder was used for 1969 Chevelles with disc brakes. This master cylinder assembly was originally known as GM #5469399. The "Chevelle Guys" can be even crazier than "Corvette Guys". So, who knows, maybe you've got a "gold mine" there?
                Thanks, Joe - now I know how to describe it correctly
