Corvette Central lists three decals relating to model year '64. 1. Harrison foil decal. 2. Shroud decal. 3. Radiator Caution decal. Are all three used or is EITHER the Shroud decal OR the Caution decal used depending on build date? Also, where are the precise locations for applying these. THANKS!
1964 RADIATOR DECAL LOCATIONS
Re: 1964 RADIATOR DECAL LOCATIONS
First off what is the serial number of your car? The Harrison foil decal is installed on the top right side of the radiator. The caution decal is installed on the top left side of the radiator below the radiator part number and build date, again depending on the build date of your car it could have used 1 of 3 diffeent caution decals. There should also be a white ink stamp mark "CT 16" on the top left side of the radiator close to the fan shroud support. Also a small green number 8 inspection sticker that can be found on the top left side of the radiator. I do not beleive there should be a decal on the fan shroud for 1964, unless it is an extremely early car??? You might want to read the 63/64 NCRS Judging Manual.
Best Regards,
James West
Omaha, NE.
1964 Corvette #9258
NCRS #18379- Top
