Oil - NCRS Discussion Boards
Oil
  • Ashley Webb
    Oil
    I am thinking of changing the oil on my low milage (25,000) 86 Convertible to Mobil 1 as I have researched and read so many good articles about it.
    Is there any problems for me in doing so?
    Many thanks for any help.
    Ashley
    • May 31, 2002
    • 169
    Re: Oil
    Ashley, I'll bet you someone has told you that the Mobil 1 change over will
    cause your car to start leaking oil in spots that never before leaked?
    I can't say that this will hapen. However I had my engine rebuilt and it now has
    about 1400 miles on it. When it was first rebuilt it had regular oil placed in
    it. I then had the oil changed after about 1000 miles and used Mobil 1 at that
    time. I now am having 2 oil leaks that have ben present for about 3 or 4 months.
    The oil leaks are from the timing chain cover and also from the rear portion
    of the engine. My mechanic said these can be repaired fooooor about $500.
    I plan on having the work done in about 2 months when my budget will allow it.
    I can't bring the car back to the rebuild shop because that shop had damaged
    my car with a interior fire which they refused to respond to. Shop claims my
    radio caused the interior fire. I has since located another mechanic who will
    do the oil leak repairs.
    Ashley I can't tell you Mobil 1 will be okay, however brand new Corvettes and
    Porche's have Mobil 1 as their initial engine oil.
    I think you should await more comments from memebers who have FACTS, not
    hunches. Good Luck, Big John
      • 15643
      Re: Oil
      The primary advantages of synthetic oils are longer service life due to lower oxidation rate and better flow in extremely cold temperatures. The additive package, which is the most important aspect of a motor oil, is the same for synthetics and mineral based blends that carry the current API rating for spark igntion oils, "SL".
      Unless you want to use extended service intervals or use your car in arctic temperatures, synthetics offer little advantage.
      Assuming you only drive the car occassionally, you should change the oil and filter at least once per year regardless of mileage.
