C1 oil pan spark plug retainers - NCRS Discussion Boards
  • Chris H.
    • April 30, 1990
    • 817
    The AIM is not clear on which bolts the spark plug wire retainers should be on. Does it go on the 3rd from the front?
    Thanks, Chris
  • Justin B.
    • March 1, 1996
    • 478
    Re: C1 oil pan spark plug retainers
    Chris, I believe that they are in the fourth bolt from the front going back. The front oil pan bolt (at the front seal)is larger (not sure of the size)than the middle bolts and that is where I started counting from. If you are counting just the small bolts than yes, it is the third from the front.
    right front oooxooooo
    left front oooxooooo
    • Dennis C.
      NCRS Past Judging Chairman
      • January 1, 1984
      • 2409
      Always seems to me like...
      ... it's just where the block drain plug gets in the way...
      • Chris H.
        • April 30, 1990
        • 817
        Re: Always seems to me like...
        Thanks Justin.
        I'm not sure how the block drain plug would be in the way? The retainer attaches under the oil pan bolts.
        Chris
        • John M.
          • January 1, 1999
          • 1553
          What Dennis said is quite true. When the clips are in the correct position, the wires will hit the drain plug in the block as they leave the clip!
          Regards, John McGraw
