'68 Quadjet Carb - NCRS Discussion Boards
'68 Quadjet Carb
  • Dennis M.
    • April 30, 1988
    • 160
    '68 Quadjet Carb
    While I was surveying my way through Carlisle this weekend I was looking for a carb for my '68 Auto. #7028208. Found a few #7028207 but no 8208. Were these used on any other GM vehicles? And are they that had to find?
  • William C.
    • May 31, 1975
    • 6037
    Re: '68 Quadjet Carb
    327 300 hp with automatic, carb is rare enough to not show up in the Mitchells or Hollander interchange manuals of the period.
    Bill Clupper #618
    • Clem Z.
      • January 1, 2006
      • 9427
      metering wise they are the same,the big difference would be the 208 would have a connection on the throttle arm for the auto trans kick down cable.
        • 43231
        Dennis-----
        I don't recollect that the "207" Q-Jet was used for any other Chevrolet applications, but it's possible that it was. The reason that you found the '"207" carbs so easily is that they were sold in SERVICE for many, many years as SERVICE replacements for all 68-69 Q-Jet applications. There are MANY of these "around".
          • 43231
          Correction
          The first sentence should have said "208" and NOT "207".
          • Dennis M.
            • April 30, 1988
            • 160
            Question Re:Correction
            Joe,
            All of the Judging Guides, Parts books and service documentation I have seen indicates that #7028208 was the Quadjet carb used on '68 327/300 hp with automatic. If you have a reference that this was not correct, what was the correct carb for this engine combination? Confused
              • 43231
              Re: Question Re:Correction
              Dennis-----
              Yes, I believe that the '208' carb was the correct one for the 1968 300 hp with THM application. I'm not sure if that carb was used for anything else, or not, but I don't think so. What I was saying is that the reason that you found the '207' carbs is that they were the ones used for SERVICE for all 68-69 Corvette (and, other Chevrolet) applications for MANY years. So, there are a lot more of these around to "find".
              • Dennis M.
                • April 30, 1988
                • 160
                Thank you, I guess I will keep on searching. At least I have a carb with the correct functions to drive until that time.
