61 c-1 front motor mount - NCRS Discussion Boards
  • William Gallentine
    On the front of the engine, motor mount on 61 should it have a hole for the generator bracket to go thru or does the adjusting bracket go in front with no hole on top right,thru the front eng support? Thanks again Bill
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Bill, In front, no hole. *NM*
    • Mike E.
      • February 28, 1975
      • 5138
      Re: 61 c-1 front motor mount
      Correct moun t "bolt" has a hexagonal section that steps the mounting arm out away from the water pump so that it clears the motor mount. Most Corvette supply houses have those (Central, Paragon, etc.)
