C1 Clutch - NCRS Discussion Boards
C1 Clutch
  • Dennis A.
    • April 30, 1999
    • 1010
    C1 Clutch
    Just a pass along...
    If a Multi-finger 10 inch clutch is installed, the Godzilla over center spring may have to be removed to prevent the clutch pedal form staying on the floor due to centrifugal force at high R.P.M.
    I understand this is not always the case...but driving brfore finding out is a problem!
  • Brad K.
    • August 31, 1990
    • 414
    Re: C1 Clutch
    Dennis,
    At what RPM do you think this negative phenomena might occur ??
    Brad
    • Dennis A.
      • April 30, 1999
      • 1010
      Re: C1 Clutch
      BRAD...
      shifting from first to second did it...
      • Brad K.
        • August 31, 1990
        • 414
        Re: C1 Clutch
        Do you mean just a lazy 1-2 shift or a BANZAI, Balls-to-the-walls, high RPM 1-2 shift ??
        • Dennis A.
          • April 30, 1999
          • 1010
          Re: C1 Clutch
          Normal...First drive after finishing the restoration. After going about a quarter mile, the clutch pedal just stayed on the floor. Adjusted the over center spring. Same thing happen, Removed the spring and everything worked great. Just finished installing an Ambrose made bracket that uses a 8 inch/6 lb. spring that attaches to the same frame bracket as the Godzilla spring. Worked great with good insurance of the pedal return. Did not fine out until later about multi-finger clutches and just wanted to pass this along...
