GM Dual Disc Clutch - NCRS Discussion Boards
GM Dual Disc Clutch
  • Dan Barton
    GM Dual Disc Clutch
    Hello
    Ihave a dual disc clutch that I purchased new from GM back in the early eighties. This was used on my '70 Chevelle LS-6 for about 100 miles and is in good condition. I believe it was an option on LS-6 Corvettes in '71. I was wondering what this might be worth. It includes externally balanced flywheel #3992094,pressure plate#231254 and the discs #3993815.
    thanks ,Dan
  • Warren F.
    • December 1, 1987
    • 1516
    Re: GM Dual Disc Clutch
    Dan:
    The same set-up was for sale in Bloomington for $350.00. I would be interested in yours. Warren
    • Clem Z.
      • January 1, 2006
      • 9427
      these clutches because of the extra weight slow down accelleration. even though the C-6 has "gear rattle" in neutral that can be silenced with a dual mass clutch GM found out that extra weight wouls slow the 0-60 mph time by .2/.3 of a second so they did not use the dual mass clutch.
      • Warren F.
        • December 1, 1987
        • 1516
        The HD dual-disc flywheel weighs 24 1/2 pounds and the diaphram cover with two driven discs and a 10" center plate weighs 30 pounds, the total of which is approximately equal to the standard BORG and BECK unit at 33 pounds for the flywheel and 21 pounds for the cover and plate.
