Valve spring specs - NCRS Discussion Boards
Valve spring specs
  • Steve D.
    • February 1, 2002
    • 990
    Valve spring specs
    I have found valve spring specs in my 63 shop manual. If a spring measures out of spec on the low side (weak) can you use shims to get closer to spec, or is it best to get new springs?
    Steve
    • 43229
    Re: Valve spring specs
    Steve-----
    In my opinion, it's best to use new springs. Valve springs don't cost that much and you can still obtain original valve springs for most Corvettes.
      Steve -
      Shimming a weak valve spring to restore its pressure reduces its effective installed height, which can result in coil bind at normal lift; you don't need that grief. Buy new ones - they're not that expensive.
