Engine and Head ID - NCRS Discussion Boards
Engine and Head ID
  • Larry Seaney
    Engine and Head ID
    Can anyone help me with the ID of an engine I have?
    The block is #3956618; build date a69(Jan 6, 1969?);front pad v0111 wk; heads #3890462 1 96. This will be the tough one I have no idea about the cam it has # cv12-3 on the end of it.
    Thanks in advance for the help.
    Larry
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Engine and Head ID
    WK 1969 350,255 hp,4 barrel,THM trans,truck
    • Mark #28455
      The heads are likely not original to this block as they are mid 1966 date and were usually reserved for 300+ horsepower motors.
      Mark
      • Larry Seaney
        Re: Engine and Head ID (Mark)
        How did you decipher the head numbers? How were able to tell they were mid-60's?
        Anyone able to offer any insight to what the cam may be using the #'s stamped on the end of it?
        Thanks again,
        Larry
        • Clem Z.
          • January 1, 2006
          • 9427
          that casting # for the heads was used from 1967 to 1969 on 302,327 and 350 cu in SBC engines. i can find nothing on the cam number. go to "google" and type in the number with the word to discribe the item,ie block,head or camshaft and see what shows up
