'68 L79 spark plug gap - NCRS Discussion Boards
  • Dave F.
    • December 1, 2003
    • 508
    Is .035" the proper gap for an AC R43 ?
    • 15695
    Re: '68 L79 spark plug gap
    Yes, but I recommend you use the R45. The R43 is too cold. I found it works well for race track hot lapping, but is too cold for the street. Even the OE R44 is too cold for the street. The R45 is just right.
    • Dave F.
      • December 1, 2003
      • 508
      Thanks Duke - off to the parts store. I may get this fired up today !
      • Michael F.
        • 745
        LT-1- this apply also?
        Duke is this also a good plug for the 70-72 LT-1s????
        Michael
        70 Mulsanne Blue LT-1
        03 Electron Blue Z06
          • 15695
          Re: LT-1- this apply also?
          Yes, AC heat range "5" (second digit of the plug number) is good normal driving plug for all small blocks regardless of displacement or power rating.
          My own preference is either the NGK B4 or Denso W-14U, both of which are non-resistor and equivalent to the out-of-production non-resistor AC 45.
          • Stephen W.
            • March 1, 2002
            • 301
            That explains why the counter person gave me the r43 ( he did call to check the number), but when I pulled the first plug it had r45S in it(327/300). Sounds like your suggestion would be to switch it back to the 45.
