1980 A.I.R. System ? - NCRS Discussion Boards
  • J P.
    • January 1, 2004
    • 7
    Many years ago, I purchased a A.I.R. system and was told it was from a 1980 Corvette. Now I'm not sure what I have. Pump p/n 7834922, Diverter Valve LJ 17063052, Check Valves 22016902, Pulley 14023171 AF (has spacer), engine bracket 14018783 (painted blue), one hose 394300 RJ DI (can't read other hose), Clamps dtd 1/80. Unit has a 4 port and 2 port tube fittings. The date code on the pump housing is hard to read.
    • 43240
    Re: 1980 A.I.R. System ?
    Mike-----
    I'm away from home so I can't confirm it, but the numbers sound like a 1980 system.
    • Craig S.
      • June 30, 1997
      • 2471
      Hi Joe - will you be at Carlisle again? I know you were unsure earlier, if so, looking forward to seeing you around G110 or Doc Rebuilds tent!.....Craig
