is this the motor that came in my 76? - NCRS Discussion Boards
  • mike budra
    how are you supposed to find out if the motor and trans are the ones that came in the car?
    Thanks,mike
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: is this the motor that came in my 76?
    Mike, you can start by posting the build date for your car, the two engine stamps on the pad in front of the passenger side valve cover, casting dates for the engine block and as many engine components as you can find, and the type of transmission (so we can tell you where to look for the numbers)...or, even better, the numbers stamped on the transmission if you can find them.
    • mike budra
      where do you find the build date info?
      • Chuck S.
        • April 1, 1992
        • 4668
        I'm not positive on a 76, but on earlier C3s, there was a stainless steel plate riveted to the hinge pillar for the driver side door just below the windshield. On the top outside corner, there was a letter and two digits stamped indicating month and date of body build completion.
        On the engine block, the casting date should be on the top of the adapter flange to the bell housing.
          Mike -
          The engine plant code stamp (which includes the engine build date) and a separate stamp which is a derivative of your car's VIN are both found on the machined surface of the block below the front of the passenger side cylinder head, just above the water pump leg. The block casting number is at the rear of the driver's side of the engine, cast into the area behind the cylinder head where the bellhousing attaches; the block casting date code is on the opposite side in the same area. Post them and we can decode it for you.
          • mike budra
            here is what i found
            ok,ill do my best to tell you what i found and where....
            on the ft of the block,pass side above water pump leg-T0201CGC
            11R143173
            on the rear drivers side of block where bellhousing attaches-3970014
            on opposite side of the above i think i saw-T-26
            and on the door jamb tag i saw this-
            Chevrolet B/9
            Trim 52 Paint 3L
            now,what the heck do i have here?
            mike
            • Clem Z.
              • January 1, 2006
              • 9427
              Re: here is what i found
              CGC 1971 350,245 hp,MT, pass car,chevelle,elcamino
              • mike budra
                so,this isnt the original motor then huh?...oh well..
                thanks for looking that up for me though.I would have never known that
                mike
                • Bob B.
                  • August 31, 1992
                  • 90
                  Mike
                  The Best thing is to start with the NCRS 1975-1977 Corvette Technical Manual & Judging Guide it will answer almost all your questions and some you didn't even know existed.
                  Bob Beck
                  • Chuck S.
                    • April 1, 1992
                    • 4668
                    "...what the heck do i have here?
                    Mike, are you sure this IS a Corvette? The trim (52) and paint (3L) codes don't fit for a 76 Corvette according to NCRS Spec book. Assuming you misread a "one" as a slash, i.e. B19, the body build date should be September 19, 1975.
                    • mike budra
                      Chuck....
                      well,it looks like a corvette.If i misread the B19,what would it be if the others were 152 and 13L?Thats what i saw on this small plate on the drivers door jamb,under the windshield pillar
                      • mike budra
                        i mean,doesnt this look like a vette to you?....i thought it was when i bought it
                        http://67-72chevytrucks.com/vboard/s...484#post930484
                        • Kevin Whiteley
                          Mike,
                          152 correspondes to Smoked Grey leather. 13 correspondes to Silver. I don't know what the "L" means. There were 6,934 Silver cars manufactured in 76. Also, I'm not sure if anyone mentioned it earlier, but the fifth digit in your VIN indicates the original engine. "L" is a 350/180hp. "X" is the 350/210hp.
                          Hope this helps.
                          • mike budra
                            hell,i dont know....
                            • Chuck S.
                              • April 1, 1992
                              • 4668
                              Nah...
                              Corvettes have chrome bumpers. (Ba-dat-bam!)
                              Only kidding you, Mike...nice looking ride. Certainly appears to be paint code 13, Silver Metallic. Also has trim code 152 smoke gray leather interior, I presume?
