Front Wheel Bearings - NCRS Discussion Boards
  • Bill S.
    • August 31, 1999
    • 104
    I checked the factory manuel for the tolerances of the front wheel bearings on my
    66 -- the range of .001 - .005 when while grasping tire at top and bottom and moving the tire in and out seems "very tight". Is this the way you check your bearings?
    Bill
    • 15690
    Re: Front Wheel Bearings
    Twenty threads per inch and six flats with two (perpendicular) cotter pin holes means each one-twelveth turn reduces clearance by .004", so there is ONE setting that will achieve the correct clearance.
    Keep moving the nut forward in one-twelveth turn increments and install the cotter pin, until you cannot feel any clearance, then back off one-twelveth and check for clearance. If a tiny amount is evident, spread the cotter pin, and install the hub cap.
    • Dennis C.
      NCRS Past Judging Chairman
      • January 1, 1984
      • 2409
      Duke, Wish you were the tech writer for GM... *NM*
      • Stephen W.
        • March 1, 2002
        • 301
        Only thing I would add would be to rotate the wheel while tightening the nut.
          • 15690
          With new bearings the nut should be slightly torqued - I think the spec is 12 or 20 foot pounds, and spin the wheel a few times. This should "seat" the bearings.
          Then back off the nut and tighten it with your fingers as much as possible, and whatever extra is required with a crescent wrench to install the cotter in the next available location. Then check for clearance. If none, back off the nut one-twelveth, and check clearance.
          As mentioned the way to check clearance is to grab the top and bottom of the tire and "wiggle" it. You should be able to hear/feel very slight play.
          • Chuck S.
            • April 1, 1992
            • 4668
            Dennis, If He Were A Tech Writer For GM...
            The first thing Duke would have said is disconnect the battery, then he would have jumped right to that part about spreading the cotter key.
              • 15690
              Re: Dennis, If He Were A Tech Writer For GM...
              Hey, that's what any good tech writer would do!
