59 wiper vacume - NCRS Discussion Boards
59 wiper vacume
  • Steve Bone
    59 wiper vacume
    I had posted earlier in regards to where the vacume line running from the canister to the carburetor hooks up to on a 230 hp 59. Dale had posted that it should tee off the carburetor mount stud and run from there to the canister and the other line runs to the vacume advance. I have searched all through my zip cataloug for the correct tee, yet, I can only find a fitting for the rear of the wcfb carburetor. Where can I get this tee. Remember this is a N.C.R.S car.
    Regards, Steve
  • Dale Pearman
    Re: 59 wiper vacume
    I posted the configuration for 1962 Corvettes (300 & 250 hp) the last time. I made a MISTEAK!
    1959 washer vacuum is taken from the rear of the WCFB through a zinc plated 90 degree fitting (0029 since changed to an 0002) This is the same fitting as used on 340 hp & 360 hp 1962 Corvettes.
    Dale
