Need help on part number - NCRS Discussion Boards
  • George C.
    • December 1, 1988
    • 583
    Have a Delco power antenna not sure if it's for a Corvette. antenna # 22062596, mast # 22143461. Thank you. Save the Wave.>George
    • 43236
    Re: Need help on part number
    George------
    GM #22062596 is not the part number for any antenna assembly and I can find no record of GM #22143461 as a mast assembly. At least, they're not the part numbers for any parts ever available in SERVICE. Where are you getting these numbers from?
    • George C.
      • December 1, 1988
      • 583
      Hi Joe, These are the correct numbers on new Delco antenna body and on mast. I can send you a picture if you want. >George
        • 43236
        George-----
        The numbers actually found on the part, itself, is not necessarily the SERVICE part number for the part. In this case, if the numbers that you're providing are correct, then they're definitely NOT the SERVICE part number for these pieces. For parts like these, the SERVICE part number is usually only found on the box that the part is supplied in.
        I suspect that GM #22062596 is the part number on the antenna assembly supplied as part of antenna service unit GM #22062597. This unit services 1984 through 1987 Corvettes. However, I can't be absolutely sure of it since I can't find any record of GM #22062596. GM #22062597 has been recently discontinued.
