C2 Ground strap connection - NCRS Discussion Boards
  • Justin N.
    • February 1, 2004
    • 318
    Dear Members,
    Today, while unbolting body mounts, I came across a groundstrap that seemed to be welded to the body? I haven't cross checked my new strap kit from Lectric Limited with the originals. The body mount, below the window washer reservoir, had a strap near by bolted to the frame and welded at the other end. I think the welded strap end was near the end bracket for my rocker molding. I can take a picture tomorrow. Thanks for any suggestions!
    Justin #41362
  • Mike M.
    • May 31, 1974
    • 8385
    Re: C2 Ground strap connection
    the strap you refer to wasn't originally welded to the rocker panel reinforcement channel but was attached by a press fit. the lectric limited strap will have the correct strap end. mike
