C1 1958 - NCRS Discussion Boards
C1 1958
  • terry leeker
    C1 1958
    Finally have the '58 on the road, thanks to alot of help from the good guys and gals on this web page. The problem: rides like a brick. Have new front springs from Corvette Central, re-arched original rear springs, full tank of gas and spare inplace. Body height is in spec's. I suspect the shocks. Rearend seems the worst. I have new Corvette Central shocks as specified for '53 -'58 replacement(non-spiral). I'm tempted to remove the rear shocks to test the ride. Anybody run up against this before?
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: C1 1958
    WHAT? Thats not normal?
    • terry leeker
      Re: C1 1958
      I'm hopeing this is abnormal. When it had front springs for the 396 and shocks in name only, it road better. Help!
      • John W.
        Administrator
        • November 1, 1974
        • 5087
        Re: C1 1958
        Terry,
        You didn't mention what tires you are running. If you are running bias ply tires, you are probably experiencing normal ride. The car is build on a 1948 passenger chassis, not exactly the tip of the tech curve even for 1958. I have a 1962, and it is much the same. I switched to radial tires and it improved the ride considerably. Still like a truck, but a 1975 truck.
        Administrator
        www.ncrs.org
        • Don H.
          • December 1, 1981
          • 1487
          Re: C1 1958
          I agree with John, they ride like an old truck. The wide white wall radials I bought a few years ago for my '60 helped but it still is a tank like ride. Don H.
          • Rob M.
            NCRS IT Developer
            • January 1, 2004
            • 12740
            and I'm loving it '-) *NM*
            Rob.
            NCRS Software Developer
            • terry leeker
              Re: C1 1958
              I am running Coker WW 205-15 radials at 28 PSI hot (I don't want to go any lower on the PSI). My 100"wb/2300lbs hot rod seemed to ride better, though it did have IFS and coil overs/solid axle rear. It could be I'm just getting old. Speaking of that, where do I sign-up to get the Prom Queens to ride on my dech lid?
