After reading some of the archive posts on the C2 small block oil pressure tube I'm convinced that I should remove the solid copper tube replacement that I purchased from the local after market Corvette parts shop and replace it with a copper plated stainless tube. Fortunately, I'm in the process of putting the interior back together and don't have the brake or clutch connected yet. However, I did connect up the parking brake which is in the way. Need to remove the pb bracket and air vent cables for more clearance. I intend to replace the tube with a tube kit from Paragon.
PS- Judging manual identifies the tube as a copper one, not copper plated SST.
Dave Kitch
Pittsburgh Tri State
2003-2004 NCRS Top Flight Chapter
Dave Kitch
