C3 Tach / heat cut off valve - NCRS Discussion Boards
  • anthony frisenda
    75 Auto - i rebuilt my tach. with a kit from mid america if i accelerate hard the tach drops to zero Any help would be great Also iwant to add a hot water shut off to my heater will this create any problems ?
  • Bill E.
    • April 1, 2003
    • 200
    Re: C3 Tach / heat cut off valve
    Hello Anthony:
    I don't know about the tach problem or installing a shut off, but I when I was looking to buy a '75 I saw two cars where the heater was bypassed without causing any apparent problems. I think,although the seller's wouldn't admit, that the heater core was leaking.
    Bill Ehri
    • Michael W.
      • April 1, 1997
      • 4290
      There's many configurations of C3s that came from the factory with a vacuum actuated shutoff valve, so the answer is no, it won't cause problems.
      • Geoff C.
        • May 31, 1979
        • 1613
        Sir:
        You can look at my website under climate control and see that it's a simple matter of hooking up a few hoses, installing a hot water shut off valve and it will all run just like the General did it himself for you.
        Geoffrey Coenen
        PS Did you follow the instructions that come with the tach board carefully?
        Even a "Girlyman" can do this :D
