1957 Window Washer - NCRS Discussion Boards
1957 Window Washer
+ More Options
Posts
  • Wayne Preston
    1957 Window Washer
    Does anyone know a source for the rubber cover on the pedal of the window washer pump for a 1957? Your help is appreciated.
  • Geoff C.
    • May 31, 1979
    • 1613
      • 43232
      Re: 1957 Window Washer
      Geoffrey-----
      The last time that I encountered a window washer was in Detroit. I was stopped at a stoplight and an entrepeneurial fellow with a bucket and squegee came up to the car and asked me if I wanted him to wash my wndows. I really didn't need a window washer, so I declined his offer (just before I went through the red light and proceeded on my way). I don't know if this guy was a 1957 model window washer, or not; he looked like he had led a pretty hard life and, consequently, estimating his DOB would be difficult.
      Now that I think about it, that guy wasn't you, was he?
      • Geoff C.
        • May 31, 1979
        • 1613
          • 43232
          Geoffrey----
          That's right! I recall, now. You once told me that you don't do windows. It must have been someone else.
          All seems to be well with Jetta. It does worry me a bit, though, just how she reacts to me leaving for 2 weeks. At her age, she's gotten a bit "set in her ways", "crotchety", and "persnickety". So, when I'm away for a long while, she goes into some sort of "panic". That worries me, but I'll likely be in Carlisle.
          I've got something else going now, too, though. Sara's mother is in the final stages of life and Sara and her sisters are doing a home-hospice thing at Sara's home. Very, very commendable but a difficult thing to go through, especially since her sisters are rather "far flung" (Seattle, WA; Richmond, VA; Clarksburg, CA; and somewhere in, of all places, Connecticut). So, I've got all sorts of things going around here that I absolutely must be supportive of.
            • 11648
            Ah yes, the Connecticut connection. Small world. Perhaps that sister should wise up and emigate from that state as my relatives have.
            Wish Sara our best.
            Patrick
            • Dave Suesz
              Is it a round
              rubber disc with 3 circular ribs?
              • Wayne Preston
                Re: Is it a round
                Rubber cover is flat, 1 1/4" x 1 3/8" x 3/8" deep. It has a hollow slot with an opening at the top to fit over the flat metal pedal actuator. There is ribbing around the right, left and bottom, with two ribs down the middle. The back is flat. Thanks
                • Dave Suesz
                  If I may suggest sacrilege...
                  The 67-68 Mustang washer pedal pad has 9 vertical ribs, is 1 3/8" wide, 1" high, and slips onto the end of a metal tab 1" wide. Commonly available from most Mustang suppliers.
                  • Geoff C.
                    • May 31, 1979
                    • 1613
                    Dave: Tssk, tssk, tssk !!! Say 10 Hail Mary's *NM*
                    • Al Corelli
                      Patrick,
                      I thought your relatives were asked to leave CT?
